Peer81
Hello everybody,
As I'm trying to get the 700r4 lockup right in my 81 I think overhere is the best place to ask as the 700 is from a 90 corvette.
The problem I have is that on my original transmission TH350C the lockup was controlled by the transmission and a little by the ECM (ecm controlled minimum mph lockup activation and brake de-lockup.) The 700r4 from a 90 corvette I now have the lockup was almost compleetly controlled by the ECM. So I almost have the lockup wiring right with some extra switches the only thing I need is a vacuumswitch that connects the lockup above ...Hg intake vacuum. (sorry no I'm not interested in the standard lockup wiring kits)
The question I have. Can somebody tell me for how long the lockup will stay active in a c4. For example, at a steady speed it's normal the lockup to work, but at 1/4 throttle will the lockup be on or off, and at 1/2 throttle?
I test drove the vette today with a vacuum gauge next to me. Steady driving at different speeds and rpm in 3rd and 4th vacuum was about 12 to 15 Hg. With 1/4 throttle the vacuum never dropped under 10 Hg. Going more throttle then 1/4 the vacuum will drop below 10 Hg (example taking over a car on the highway). So I'm thinking getting a switch which closes above 10 Hg. Any opinions on this one?
As the C4 lockup is ECM controlled it's maybe in relation to the TPS position?
Greetings Peter
Greetings Peter
