get a crate
mst said:
Kinda in the same boat as BigBrakeFuelie. Debating on swapping out my original 350/270hp with a HP 350 or 383. Of course I'll keep/store the original motor. Just went through all the suspension, steering...etc. Guess I'll shop around and decide what I can or want to afford. Heard crate motors were the way to go.
First, welcome to CACC! For most folk, crate motors are the way. Also for most folk, horsepower/torque & power band considerations may not've been understood. For average-to-spirited street performance ... big Torque is king ... "useable power" equates to torque. For drag racing & low e.t. ... high Horsepower becomes more important. Keep in mind our C3s can be VERY unforgiving to lower manifold vacuums ... Big horsepower is all-to-often accompanied with low vacuum.
Take a look at GM Performance Parts' factory sbc crate known as HT383 (GM as in Chevy). 4-bolt main, forged 3.8" stroke crank, 4" bore, roller cam, 9.1:1 CR (great for street & pump gas). Comes with iron L31 Vortec heads. Rated at 415 TQ, 325 HP on required minimum 87 octane ... under $4000 complete less carb & dist ... with GM warranty ... PN 12497317. Also, HT383 short block available from GM.
http://www.sallee-chevrolet.com/ChevySmallBlockV8s/HT_383.html
Also take a look at link below to Hot Rod Mag's six-step buildup of an HT383. BTW, I verified all those HRM dyno results (including baseline) were with 91 octane “76 brand” fuel.
http://www.hotrod.com/editorial/art...e=text&id=66278
ZZ450 - 458lbs torque, 450hp ($5550 @ sallee chevy pn SC450BLB) aluminum fastburn heads, 4” bore, 3.80” stroke --- requires minimum 92 octane
ZZ4 - 405lbs torque, 355hp ($3525 @ sallee chevy pn 24502609) aluminum heads, 4” bore, 3.48” stroke. Upgraded to 395hp via HOT roller cam & 1.6:1 roller rockers ($4195 @ sallee chevy pn SCZZ4-6) --- either requires minimum 92 octane
385 Fast Burn - 385lbs torque, 385hp ($4075 @ sallee chevy pn 12496769) aluminum fastburn heads, 4” bore, 3.48” stroke --- requires minimum 92 octane
350 HO - 380lbs torque, 330hp ($3195 @sallee chevy pn 12486041) iron L31 vortec heads, 4” bore, 3.48” stroke --- no published minimum octane requirement (likely 87)
Goodwrench 350 - 304lbs torque, 249hp ($1575 @ sallee chevy pn 10067353) iron non-vortec small-valve heads, 4” bore, 3.48” stroke, replacement engine w/ 3 yr/50K mile GM warranty --- no published minimum octane requirement (likely 87)
HT 383 - 415lbs torque, 325hp ($3750 @ sallee chevy pn 12497317) iron L31 vortec heads, 4” bore, 3.80” stroke --- requires minimum 87 octane
I’ve done the “build a stroker 383” thing (actually 388ci). IMHO I did it for FAR less dollars than a similar crate or local-build from anywhere ... but it’s COST me a whole lotta aggravation, wheelin’-n-dealin’ and TIME ... and no warranty. I don't drag race, but I do like a spirited car. Little doubt in my mind, if I were to want a similar stroker again ... I’d probably buy the HT 383. If I didn’t like it’s heads I could easily sell them (they’re real popular) ... or I’d get the ZZ450 for about $1800 more.
JACK:gap
