- Thread starter
- #21
J
jmp
0018 said:Having owned all 3 years of LT-1s, the 1970 is without a doubt the fastest. Rated at 370 H.P., this high compression small block put out over 430 horsepower. The 370 H.P. rating was an insurance dodge. Government emission regulations eventually killed the LT-1. The Compression ratio was reduced from 11:1 to 9:1 in 1971 to be compatible with the new unleaded gas. Ignition timing was reduced from 12 degrees advance, to 8 degrees on the '71s, to 4 degrees on the '72. Valve timing was also retarded to meet the new emission laws. The LT-1 was becoming "too tame" to carry on the legend it started in 1970. I personally am glad Zora decided to pull the plug on the engine he wanted for so long. I would hate to see the anemic engines of the mid and late '70s being badged as LT-1s. I have heard of early '71 LT-1s being equipped with leftover '70 high compression engines. All three years are great cars, and worthy of the LT-1 designation. Unfortunately Uncle Sam and the environmentalists had to put a damper on our fun. Maybe its a blessing in disquise, if the LT-1 was to become a common Corvette, like the L-82, that wouldnt be much fun either. Drive 'em. Drive 'em hard! Thats why Zora built 'em in the first place....FUN!!!
OK, I'm bringing this back up again, but with a slightly different slant. Btw, thanks for the info 0018 -- very helpful.
I'm wondering about putting some of the oomph back into my 72 LT-1. I don't want to go aftermarket or even really hybrid, but is there anything I can do to counteract the changes made to the 70 LT-1? Increase the compression? Change the ignition and valve timing back to 70 settings?
Btw, how did they reduce the compression? I think I know of a couple of ways to increase compression, but not really of decreasing compression, unless they -- what? -- changed the block, heads, or pistons??
