I was messing around with the brake lines and noticed that my power steering box was pretty dirty. A memory floated up of a steering system that was in need of work. I remembered driving my '87 for the first time and feeling like there was something wrong. You moved the steering wheel a tiny fraction of an inch and the car moved. My '72 did that but there was a comfortable lag -- like you could start to turn and change your mind because the car was still going in the same direction.
I confirmed the play in the steering box and logged on to several Corvette sites. It was very clear that I had to do something. There was a thread on a Jeep steering box that only required a couple of new holes in the frame and some gentle dimpling of the header.... OK, I might have gone with a Jeep solution but hammering on a brand new set of Jet-Hot coated Hookers just didn't make sense. Then I found a Borgeson thread and it looked better but still mentioned the possibility of header adjustments. The option I chose was the Steeroids rack & pinion conversion.
Steeroids isn't a perfect solution but I've owned both recirculating ball and rack & pinion cars. My brand new '68 GTO had the former and my used '87 Corvette had the latter -- decision is easy. Almost everything on the Steeroids conversion was a piece of cake. The only difficulty I encountered was the coupling at the end of the column. I couldn't get it on. You're working on a raised (jackstand height) fender with a master cylinder in the way and trying to line up two non-obvious angled pieces. Obvious solution is to pull the steering column. Dash was already out of the car so it was no big deal.
Once it's out I can easily clean the splines on the shaft and dress the edges with a jeweler's file. The coupling goes on with no problem. That's when I should have just put the steering column back in the car and hooked it up. Instead, I noticed that the four bolts holding the power brake booster were visible and relatively easy to remove. This would be a perfect opportunity to paint the booster. Maybe even buy a chrome booster and master cylinder setup. Boy, does that ever open up the driver side of the engine compartment.
Another visit to a Corvette website and the only possible solution to my brake problem is hydroboost. Actually, the problem was that the DOT-5 fluid had leaked out of all the rebuilt stainless calipers and there was an oily look to the master cylinder. OK, hydroboost it is. Ordered a ready-to-install system and waited. When it didn't show up (actually it showed up on my credit card account the day I ordered it) for four weeks, I called. The UPS status hadn't changed for four weeks (info entered) so I was told it was shipping the next day. A week later I called the manufacturer and he had no order from the dealer I used. The reasons why this happened are all reasonable and very sad -- so I cancelled the order and looked up a rebuilt hydroboost unit on Rock Auto's website. Decided on a 1993 Chevrolet 1500 diesel pickup unit (only because the core charge was $20).
A chrome master cylinder cover and foam gasket for the original booster so the new one would seal up against the firewall also came off the UPS truck. Removed the firewall mounting plate from the hydroboost so I could cut off that ring on the end of the pushrod and cut some threads to match the stock clevis and jamb-nut. Knocked the mounting bolts out of the plate and noticed the flange and gasket were not a perfect match.
There are a couple of places on the car that have superficial rust but the steering column and brake mounting bracket rust rust wasn't a big worry. I should just leave them alone.... OK, they came out, and got bead blasted along with the seat tracks.
That hydroboost unit didn't look that great and as long as I have to wait for the mounting plate and a few other parts, might as well wire-brush the paint of and give the accumulator a little polish. All those blasted parts need a coat of epoxy primer....
Before I put the steering column back in the car, a remark in one of the threads is nagging. They said to check the lower bearing for play. I give mine a jiggle and things start moving. Oh-oh -- this looks like an opportunity. "While I have it out" becomes a complete dis-assembly and an order for some parts, including the critical Key Buzzer Switch. Mine was intermittent so when I got to the point of removing it, it fell apart. Next batch of parts that need epoxy primer will include some of these....
