Does anyone know which lead is which on the bottom of the relay? Which side is supposed to be the green wire and which the black?
Here is my problem. The horn doesn't work. If I jump the green wire (at the relay) to hot the horn sounds.
If I put a test light between hot and the black lead and press the horn button I get nothing.
Also, if I connect the side of the relay the black wire was on to ground I get nothing. No click, no horn.
I may have two problems... or perhaps the relay leads on on backwards...
On my car, if you are looking straight at the relay the green one is on the left. The black lead is on the right towards the front of the car.
Thanks!
-Gooney
Thanks!
-Gooney
