72Slydog
Need help with a 1972 tachometer problem. I installed a new tachometer cable to eliminate popping sound. After installing the new cable, I can't get the tach to return to 0 when the engine is shut off. Removing the cable from the distributor, rotating the inner cable and reinstalling corrects the problem. Problem starts again after next startup and engine shutdown sequence. Replacement cable is the exact duplicate of the original cable. Lightly pulling on the cable from the engine side will also reset it to 0. Tach seems to work fine during normal driving. Any suggestions would be greatly appreciated.
