H
Hijinx
I have looked through the old threads on suspension upgrades, but need some validation. As a starting point, I have recently installed KYB Gas-Adjust shocks all around and a VBP 330lb rear fiberglass spring.
First, I need to go through my front end and replace all of the bushings and such. I plan on putting in a poly-graphite kit, I think that is a no-brainer. So the front end will get a full kit with these and new tie-rods, ball joints and such.
Question 1 - What else should I consider doing up front? Chris - I know you put the VBP front mono-spring. I dont really plan to race my Vette, however that is a pretty slick setup. Do I spring for it? It looks like you lose some ground clearance with it, which on an already low car may not be a great deal.
Queston 2 - I have heard that the KYB Gas Adjust shocks I got are not a good combo with the rear fiber spring. VBP tells me I should have gone with the KYB GR-2's or the Bilstein Sport shocks. I have to admit that handleing is OK with the Gas-Adjust, but not great. (Possibly not as good as with the old shocks I had). Ride is a bit better though.
Question 3 - OK, I am probably already looking at $1000 of front end work, unless I do it myself (which I might). I hate to not address the rear end to some extent too. I definately want the VBP Smart Strut and the Diff Cross Member Reinforcing Kit. Should I do this without rebuilding the rear trailing arms? Mine are working fine, with no extra sounds or slop. However, they are very rusted and scaling. I know that this would be around $2000 to rebuild (If I dont do it).
I could sure use some advice here guys. You know the Vette suspension better than I and I want to do it right - once! With plans to put around 400hp under the hood, I need to suspension to work. Thanks for you input up front.
