Help! 74 Vette. Stingray emblem. How do I remove them?
They have two tabs for alignment but no nuts on them. Try to use some fishing line to get between the glue and the fender.
Fender scripts might have emblem tape holding them on, especially if they have been off the car before now.
Nose emblem probably has two speed nuts on the underside.
You get a break on the fuel door emblem.
The Stingray emblems do not have nuts on the back of them. The pins are just for alignment. The emblem is held on with adhesive.
If your emblems have an adhesive backing, use a heat gun. Emblem should peel off leaving only a slight glue residue which comes off easy.
Unsure which ones do or not,but I guess I should pick up a heat gun. Cold around here!
