75,000 On OD—Oil??
Donne Trav
Washington, DC
1994 Blk/Blk
I've got a little over 75,000 miles on the OD, what weight oil should I use
at this juncture? THANKS:pat
Unless you are having problems, then my recommendation would be to continue using Mobil 1 5w30 or 10w30 as appropriate for your temperature ranges.
I used Mobil 1 10w30 for 14 years in my ex-'92 LT1 and it was in perfect condition at 103K miles when I took it apart.
OD oil
I think he is talking about the oil in the overdrive unit. If you have an owners manual, I would look in there and use what they recommend.
OverDrive or Odometer? My response is based on the list if Corvettes and I see a 1994 which does not have OverDrive on the trans.
I believe the type of oil is not as important as the regularity of the oil changes.
Another vote for M1. 93 has 103,000 that includes 5 Big Bend races and still has the cross hatch in the cylinders, rod & mains look great. Blown head gaskets (and the desire for more power) prompted the tear down.
