HEI Trouble Shooting
Any good auto parts store should be able to check both coil and module.
Brian
My 81 shop manual give trouble shooting method defined on the two attachments included with this reply. Hope they help, assuming your 77 ignition HEI is very similar.
Additional here are some of the problems / fixes I have made to my 81 HEI over the years, that may give some other causes no spark problems.
1. Check the Distributor electrical connectors (my system has three) for missing / broken retention snap clips (part of the connector housing), without the clip the connector may have fallen off or backed off enough to kill the spark output.
2. I made a retaining strap from some stainless steel safety wire, it goes around the back of the connector housing and up and over the HEI coil / distributor cap terminal housing.
3. Check connector loose, or damage contacts, replace anything suspect.
4. Remove distributor cap assembly, mark each spark plug wire for error free re-connection. Then check: the center spring loaded contact end for excessive wear or a weak or broken spring, worn contact seal, check rotor contact finger & contact posts inside the distributor cap (transfers the high voltage from HEI coil to rotor, then to spark plug via the spark plug wire). Check inside of the dist cap components for cracks, contact wear, erroision, deposits, oxidation, etc.
5. Using the two attachments; Check HEI electrical condition, with an ohm meter, perform the resistance checks as defined, to determine if coil is good or bad.
6. If the coil test shows bad, then remove the coil cap assembly and inspect all electrical contacts (hard wired to the coil) are position correctly and are undamaged, verify the coil secondary ground lead is connected correctly and un-damaged (no ground, no voltage output).
If you are up to these trouble shooting steps, then you may not have to go the professional test / repair cycle.
The above condition are more likely if your ignition system is either factory original or to OEM spec and have been in service for years or have been subjected to less that desirable garage conditions. I have even had a case were a mouse eat through several ignition wires and spark plug wires, etc, which caused all kinds of weird ignition malfuntions.
I hope all this detail helps and doesn't cause too much confusion, this is a prime case where it really helps to write down each step and the result of same.
Good Luck!
