Z
zackster
Hi guys,
Let's see how good you are. This one will test you!
I have a 77 Corvette L82. After running the car long enough to warm it up, I shut it down, wait about 5 minutes and the little light down by the spare tire comes on, the rear window defogger has power ( it doesn't come on unless I switch it on, but it has power ), and the power antenna comes up! There was an aftermarket radio and power antenna on the car when I got it. At that time, even the radio would come on! I have since changed the radio and it works properly. If I run the car long enough, the power to all of the above doesn't even go off until the car has a chance to cool down or it runs the battery down. Do you have any idea what may be causing this? I have a manual for the car and it doesn't even show the little light by the spare tire. I'm beginning to wonder if light is original equipment.
Frederick Zachery
Texarkana, TX.
(903)793-5528
Frederick Zachery
Texarkana, TX.
(903)793-5528
