N
NU2VETTES
I am going to start the interior of my 79 tomorrow (Labor day) and have 3 problems that I would like to fix concerning the center console. Before I decide to break anything, I am asking for any know how you might have on how to take the console apart and make these -- what should be --- quick repairs.
1- The radio is crooked and needs to be straightend. SHould just be a matter setting it in place correctly and tightenting a bolt/nut.
2- The vent/ac switch unit is loose from the console on one side(passenger side) --- hangs down out of the console -- also I found a new clear plastic plate that would seem to fit over the ac/vent switch unit when mounted properly into the console -- do I take the entire unit out and remount into the console? It looks like that would be the only way to do it.
3- I know this sounds odd but--- the little peice of plastic that moves when you move the shifter from park to drive is broken inside the shift indicator. It is just laying in the area marked R N 3 2 1. How in the wide world of sports does that thing get fixed?
Any help would be appreciated. Thanks
