Johnw222
I am really lost at this point as well as several others around me in finding the fix for my 79 L82. My top radiator hose continues to build so much pressure that it adventually blows of! Now let me tell you what I have replaced or went over. I am on my third radiator (2 New ones), I have replaced the thermostat 3 times drilled a small hole in one, ran without a thermostat, replaced the water pump, replaced the hoses upper and lower and transmission cooling lines, replaced the cap 3 times to include a pressure relief cap, replaced the hosing to the overfill bottle, replaced the overfill bottle cap ran without the overfill cap. At first the top hose was completely compressing shut and literally sucking it off of the radiator. Now the pressure builds so much that it blows off. I tried to fill the top hose with antifreeze and/or water to rid of any air pockets in the block, I flushed the system with and without the water pump on. The temp is not exceeding 185 either on my dash instrumentation nor a measured temp from the radiator fluid.
I am exhausted. Please help if you can.
John
John
:confused
