Vette Suzy
New member
I just replaced the water pump, thermostat & upper radiator hose, bled the cooling system but my car now overheats. It NEVER has run any hotter than 175 so 200 plus degrees is not the norm here. Will check the lower hose. Thermostat was tested and works. Any ideas what to try next? Thank you. :confused
