widewhites
Active member
The colum on my 79, has some play in it where it tilts. It isn't too much play. When you pull down on the wheel you can feel the tension of the spring(?) It pulls down and to the left. I was told that you can fix that by tightening up a retainer bolt in the column that keeps the tension on the spring. Sounds logical. Suggestions.....thanks!
