T
TMPJoe
after milling you are up around 10:1
on 93 octane that will make you run pretty warm for the stock cooling system as well
i have a much wilder build and I had to go with a Becool radiator with twin fans.. i still fight the heat all the time
get your tune right... remember fat motors dont blow.. a few hp down on top end but they last a lifetime... ! nice work.. like the way you do your finish items
i run 10:5 to 1 and 39degrees straight .. no advance.. so I push it hard but a lot of the guys I see find the stock system in an L48 (which is what mine was) just is not up to the task at hand when you step up the power...
good luck!
good luck!
