I've been looking for the source of a transmission leak for months, and have just found it. When I removed the metal cover from around the converter/ flywheel,
hyd fluid starts to come down very slowly from inside. I'm told there are about 3 different seals that may be leaking. The question is, how hard is it to get the tranny out, and also to replace the seals. Also about how high do I have to get the car up in the garage to remove the unit. Is it worth the effort, or should I have the job done in a tranny shop?? Any information would be a great help, and much appreciated. Also, is the modulator valve on top of the transmission??
JohnnyJ
JohnnyJ
