agildawg
Active member
After MONTHS of shoppng and reading forums, I just got an 81 and am working thru all of the bugs. The power antenna was non-functional. A previous owner had cut the wires at the antenna. After removing it, I was able to determine that the motor works when power is applied (thanks to previous posts), but the middle section of the mast is bent so I will need a whole new mast, not just the repair piece with the top section. Are there any masts out there to be found? Any masts compatible from other chevys? Also, I drilled out the rivets on the motor cover, but still cant get it apart. Something seems to be holding it together in the center of where the gear is. Any tricks to getting it apart without breaking it?
If I can't get it repaired, do you guys have any recommendations on replacements? There seem to be a wide array of options, some that are direct replacements for about $180, and then some much cheaper. If it matters, it currently has an old (but non-original) delco am/fm/cassette in it that I plan to replace with an aftermarket unit. Will my plans to replace the radio affect what I do with the antenna? Rik's Vet has an antenna that will plug right in, but they say it only works with Original radio and antenna. I know about having to bypass the antenna relay if you put in an aftermarket antenna, but if the antenna is working properly, what is the issue with an aftermarket radio controlling it?
Thanks for any help you can give to an excited newbie!
Regards,
Ron
Regards,
Ron
