tcxd40
- Joined
- Mar 7, 2007
- Messages
- 387
- Location
- Pittsburgh
- Corvette
- (2) Black '93s, purple '81, '69 vintage racer
Ok I'm at wits end here.
The '81 has approx. 77K and sat in a barn for about 17 years. So when I got it home, via trailer it did not run. I changed everything that would normally be done. Plugs, wires, cap, rotor, module all new. Also checked the coil and pickup coil both tested good. New fuel pump, carb filter and rubber lines, tank and pickup cleaned, lines cleaned via compressed air. New starter was installed too.
It never ran too good when it did run, now it won't start or try to start. Have spark and fuel, good battery, just spins and maybe coughs once every revolution or two. When the plugs are pulled they are soaked and black.
Items not changed distributor, carb, and computer. A.I.R pump is gone.
What I'm I missing? Any suggestions from here on out?
tcxd40
tcxd40
