- Moderator
- #1
bill81vette
Moderator
Gail took the vette to work this am...called me at noon time when she was going out to the bank and told me the vette wont start and what can she do to fix it...(oh sheet):confused
any way went over after work and nothing is happening ,plenty of power(tried jumping,nada.),everything works,with and without jumping....
nothing happens on starting circuit...have not tried to bypass the circuit and go straight to the starter(no room),will try in am if need be...
I tried,and had her try, to giggle the shifter in park and in neutral while having the key in the start position..
how can I check the neutral safety switch is bad,and I'm going to pull the alarm switch in the am on the off chance she may have activated it.unless I can figure out hoe to deactivate it without taking it out...should be able to by unlocking the door I would think...
she told me she had a hard time getting the car to lock and unlock today b/4 she had trouble with it....hmmmm I wonder????
have not had any problems with this prior to today....its been starting and running like a champ so far this year!!!!!
