J
jdsworshop
I just replaced my alternator and the fusible link that leads to the battery. After doing so, the car will not start. When I turned the ignition off, the injectors started running. The only way to stop them was to pull the fuses. There is no gas coming out, but I also can not get the pump to work. The fuse for the pump was good. I also noticed that the check engine light is on dimmly when the ignition is off. Any ideas?
