F
fatboyreyn
hey guys, need some help with 1982. sat for 14 months. was told it ran great before it was parked. emptied fuel tank, changed fuel filter. checked pump, there is flow. ( jumpered wires at relay. Put new injectors and gasket kit and cleaned everything up. Now the problem. Car starts right up if I pour a little gas in throats. When I turn the key, injectors sometimes spit for a second, but not a spray. When the car is running for the few seconds after I pour gas in, the injectors are again trying to spray, but it is far from a fine mist. Is the spray from the injectors supposed to be a nice strong spray? Is it possible the pump produces flow but no pressure? I didn't do anything with the regulators on the bodies. I also tried keeping the jumper on the pump relay while trying to start it, but still comes out of injectors sloppy. Any advice, boys?
