wishuwerehere82
- Joined
- Sep 6, 2003
- Messages
- 2,316
- Location
- Rochester, NY
- Corvette
- Red '82 Coupe,Sebring Silver '98 Coupe
Hi everybody, I am going to throw this out in case any of you have seen this before.
I have an 82 that I rebuilt myself about 5 years ago.
Everything in the engine besides the block, crank,and rods are all new, with fuelie cam,.020 over pistons, Cloyes timing chain and gears, Hypertech chip, but basically rebuilt to stock.
I have all new sensors and AIC motors which made a BIG difference in performance, but I still have a periodic surge in RPM at idle once the engine is warm. If I stop to get a burger and come back the idle goes up and down (650-1100 RPM every two seconds) until I get to a sustained speed under load.
I have been working on this for about 3 years and have re-tuned it several times. I understand the AIC motors cycle if it detects RPM under 500, but my idle is set for 650-700, with a TPS voltage of 0.525 Volts, but it seems to run smoother as I set it for a lower voltage(around 0.5 volts).
I installed a MadVette throttle position sensor enhancer module, and that keeps it from doing it at highway speeds at steady throttle after accelleration (really scary on curves) but still it does what it wants at idle, especially when it's really hot out.
I have a friend who has had an '84 (with the same engine) that has done this since he bought it new. Any ideas if this is just an artifact of Throttle Body Injection, or is this a fixable problem?
