gunpowder44820
Help, The car has been carburated, crossfire removed. Just put new compressor ,dryer,flushed system, ran vacuum, all good. Prior owner cut the vacuum lines that ran thru dash to the part that sits behind glove box. He removed the lines that went thru firewall and put in glove box for next owner to figure out.I'm the new owner, Now what? I think I can order new vacuum lines but have no idea where they go. Secondly we had, I said had cold air coming out vents, but by moving the levers back and forth now we only have cold air on floor, very little coming out vents, what happened and where can I get a schematic on where the vacuum lines go,? Lastly , where do I bet vacuum to run all the actuators, I have a holly carb, can I put a t in line somewhere, should I use high or low side for my vacuum,? I know I have asked not of questions but you have all helped me before Thanks
