L
L98corvette
Hi guys, i have done a complete tune up on my 91, it has 83,000 mi on it, runs great, should i go ahead and change the oxygen sensor??
It might be cheaper than that actually Edmond. Autozone has them for 18.99. On that note, why not change it just like Edmond said.Edmond said:For the $30-40 that it would cost you, I would do it. It will restore driveability, fuel efficiency and response back to where it should be.
vetteboy86 said:It might be cheaper than that actually Edmond. Autozone has them for 18.99. On that note, why not change it just like Edmond said.
Robertwav1 said:I'm gonna check into that myself for that price. Is there just one for a 93? I've been under the car enough times but don't recall.
If it ain't Broke,Don't fix it!! If it is not tripping a light or code it's not broke!!John Robinson said:According to my Service manual on the 93 there are two O2 Sensors. They are the heated model and each one is in the cat for each exhaust manifold. This is the case for Both the the Vin P and Vin J engine. I also would be interested in the price from Advance Auto I believe these are more expensive because they are the heated model. The manual does have a very good section on how to check the sensors in the car. I have an old addage if it isn't broke don't fix it. If as you say the car is running fine why spend the money. I believe you will know when a sensor goes bad.:confused
I'd do the Job Right the First Time!! The second time the Job don't pay worth a Damn!!:ughEdmond, do you like the Denso, Bosch or A/C Delco sensors?Edmond said:That's the problem, the sensor will gradually start to fail and your perception of mileage and throttle response falls underneath the threshold of sensory because you're driving the car constantly.
I still say to change it. If it is an original from '93, it is time. Changing parts isn't based solely on mileage or failure. In theory, that sensor could be in a garage queen that has 20 miles on it and fail because of age. It's a sensitive electrical component we're talking about here.
gmjunkie said:If it ain't Broke,Don't fix it!! If it is not tripping a light or code it's not broke!!I don't use after market sencers anymore!! I have had BIG Problems with after market sencers and EGR's from Advance and Auto Zone!!!!!!! (Sornsen,Thomco,BCS,Autolite,Nepco) If it is not AC on a GM your just asking for Problems!!
Robertwav1 said:Good advice, that's what I'll do. No lights ... No codes ... car runs well ... 80K .... I'll think about it at 100K again. I guess the best thing to do is remove them first and take them with you. I always run into some question that I don't know and get the wrong part. This much I have learned
Edmond, I've read that somewhere also to replace every 60K. What about all the other sensors? I sorta like to trust the CPU to tell me when something's wrong.... unless there's a malfunction with it of course. Parts are expensive and I have a tendancy to replace only when needed. My opinion of course. Enjoyed all the comments on this!
gmjunkie said:I have had BIG Problems with after market sencers and EGR's from Advance and Auto Zone!!!!!!! (Sornsen,Thomco,BCS,Autolite,Nepco) If it is not AC on a GM your just asking for Problems!!I'd do the Job Right the First Time!! The second time the Job don't pay worth a Damn!!:ugh
BLACKTALON said:I thought my fuel filter had something to do with why my car doesen't have the shread the rears any more.I jus hit 73k and I knw now that the O2's need changing. My AFR is 12 alway across the last time we dynoed.![]()
