I know this has been beaten death but I need help with a cluster repair. I have read and tried to digest all the repair links. My original problem was the usual display goes out and the signal and hi beam indicators come on. I read all the info - pulled the cluster and found the dicolored pin connectors just like described. I cleaned them - made sure the connection was good - checked the sodder joints - put everything back together and turned the key. To my surprise it worked perfect - until the car is driven for 10 - 15 minutes. Then the dispaly goes dark. In daylight you can still see it - but it's dim. At night you can't see it at all. The ground concern seems to be fixed - no more indicator lights coming on but what did I miss? Is there something I can still do or should I just give in and get a rebuilt cluster? Thanks for any and all advise in advance - Jack
