Glava2876
I have been going through everything and have a couple more interior questions about my 84 and just a reminder, this is my first corvette so I may be asking stupid questions;
1) When I turned on the lights last night, the knob came off and I'm trying to figure out if it is broken or if I just need to figure out how it goes back on. At this point, there is a shaft with a triangular metal clip that fits into the back of the knob -it will slide back on, but won't stay, is there a tab or something that needs to be adjusted?
2) The interior courtesy lights all work when I rotate the light knob, but they won't come on when the doors are openned -is there a switch override somewhere that is shut off? The under hood lights also didn't come on when I was working under the hood -is this related to the interior cortesy lights?
3) The horn won't work -I have not started looking at this yet, but are there any common problems that I should look at first?
The hood release surround is hanging down and there is nothing above the single screw hole -it there a plasic tab broken off, or is there one of those metal screw clips missing?
Thanks in advance, Glen
