G
geofamy
someone cut off the ele. plug to my cooling fan relay and set it up to run all the time. I am puting it back the way it should be. Can someone look at there 84 cooling fan relay in front of the battery on inside curve of wheel well and tell me if the big red wire goes to drivers side of the plug,and the big black + red wire goes to the passanger side of the plug and the blue small wire goes next to the big red. and thesmall green + white wire goes next to the big black + red. The two small on inside,and two big on the outside. Is this correct, If not please let me know... Thank you
