Cartrax
Getting a reading of infinite resistance on my knock sensor ("84 Vette). My research is unclear on this. Anyone know for sure if this is an indication of a bad knock sensor?
It generates a very small voltage when it 'hears' a knock. My DVOM was sensitive enough to show a momentary indication when the sensor was lightly tapped, on the bench. More, and harder tapping, generated a higher voltage.
Resistance readings can be helpful in IDing if you have the correct sensor.
