vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
Further Info
The TB that has 5 VAC connections
( The Front one)
#1 Connection( the large one for PCV valve)
#2 EGR MANIFOLD VACUUM
( next to the PCV large connection)
#3 The MIDDLE small connection is
"AIR CLEANER MANIFOLD VACUUM"
to the right ( looking at back )
#4 The TOP one ( with a tweek in it )
is PORTED vac for the canister purge.
(I think that's the one you want for syncro )
#5 The one by the throttle screw
MAP sensor manifold vaccum.
So it really dosent matter where you pick up vac to run certian stuff.. but it DOES matter if the function of the port is above or below throttle plates.
Vig!
( The Front one)
Vig!
