I
imogden
85 4+3 99k
It use to run not so bad, then I had a tune-up. They replaced the sparkplug wires also. The non-mechanic at the shop cleaned out the TB which I still think is the main cause for all my current problems.
During the tune-up, the mechanic broke off the bottom bolt holding on the TPS, the end still in the TB is flush, cna't remove it. Thought about a replacement, rebuild stightly bored out to 52mm TB, but that's $200+ on ebay and a lot of time r/r it. Then they told me my original TPS was bad and I needed a new one, bought that, same results, rough all the time. The bottom TPS bolt is still missing today.
After sitting most of the time over a couple of years (sat more than driven, like maybe a 1000 miles a year), i took it to another garage. He found out that the gas tank had a lot of water in it. He drained the tank, put fresh gas in it, new fuel filter, but still rough. During all this, I left my gas tank cap at the pump and drove off, thought that was why the tank had water. I put in a dry gas additive for fuel injected engines a couple of times, does not seem to help.
Another oddity that I think is a problem, when I get gas, when removing the cap, it seems a lot of vacuum has built up in the tank and I hear a sucking of air sound (really strong) when removing the cap. That may also be causing the water in the tank when the boot gets clogged and filled up over the bottom of the gas tank lip, the vacuum sucks in the water!
1. Is this vacuum sounding stuff suppose to happen, if not what can be done to correct it?
After another year and wanting to drive the vette more, I took it to someone who recommended anothr mechanic, he also did a tune-up. He said the timeing was off alot. Said I might need wires again. I did not have him replace them.
Today, it runs better than it has in the past few years, but under throttle pressure (other than the pressure to just cruise) the engine stutters almost like a cyclinder is missing, but let up on the throttle and maintain speed, it's as smooth as silk.
Love the car, looks great from a distance. I am second owner, 3months old when I get it, have had many many great times with driving and enjoy the moments.
Has anyone else had a similar problem?
Thanks for reading.
Bob
Thanks for reading.
Bob
