D
ddvette
I'm a new member, but have been using the knowledge base and gained alot of info. Here' my problem... I replaced spark plug wires a couple of months and saw a great running difference, but about 2 weeks ago I got a really unexpected start and stall condition when trying to leave work. Got it running enought to get home (limping and backfiring) and put it in my garage to see what was up. Starting by cleaning the TB and plenum and while in there replaced vacuum hoses, EGR valve, IAC. Since it's winter here, I decided to do the fuel filter and fuel pump. Same results - start and immediately stall. Took the starter out and cleaned connections. Didn't think it had anything to do with my current problem, but that's when I caused more trouble.
I had the starter looked at at the local parts place - they said it was ok, but started "chattering" while on their test machine. I put it back in, but wasn't convinced that it was good. Since then I've had a no start, no click, no crank condition. Before I take it to my mechanic, I decided to replace the starter (AC DELCO). Same condition (no start, no click, no crank).
Anyone have similar experiences?
