gibbsrc
The GM service manual schematic supplement shows a 15 amp fuse added to the later '85 models in-line under the right side dash. I have increased this to 30 amps and still it blows the fuse. The rear window and side mirrors defrost fine until the fuse blows, but the wiring gets hot and the hatch struts also get hot.
Today I disconnected the rear window and the mirrors heat without blowing the fuse. The resistance across the window measures 0.4 ohms. With a normal charging system voltage of 13.8 volts, 34.5 amps would be required (not including the mirrors). This would explain the blown fuses.
Looking at the window, I see 14 lines wired in parallel on each side. The two sides are wired in series. There is a strange braided cable soldered directly against the window at the top and bottom.
I can't understand what is wrong unless (1) this is an after-market window with an incorrect defrost grid, (2) The soldered braided cable is something that a previous owner has added, or (3) this is a factory design problem.
Can anyone verify that the soldered braided cable on the top of the window is factory design and not some type of after-market mod.
