M
mdsbch
I have an 85 coupe. It was missing the front roof panel hold down pins part# 14051195 on both sides. These are cone shaped nuts that trhead on to the bolts sticking out of the roof panel in the front. I bought a couple of them and put them on, but now the bolts to hold the roof panel down are very hard to start. Before putting these on the threaded part on the panel would move around freely and was very hard to get lined up. With the cone shaped nut on it has locked the threaded part down so it doesn't move at all. My question is, should they be tight to where the threaded part doesn't move or should they be able to move around a little? If so, should there be a spacer under the cone shaped nut or are they just not supposed to be tightened down all the way? Thanks for any help.
Save the Wave!
Save the Wave!
