ghr4news
I've read through the majority of the postings about headlight problems and haven't found one yet with the same problem I'm facing, thus this thread!
The passenger headlight in my coupe works off and on; meaning it opens every now and then. The light turns on and the mechanism to open the headlight works for about a second but then the headlight wont go to the open position, the light just stays on in the closed position. There is no motor rumbling noise as if to indicate one of the gears is shot. I get the feeling it might be an electrical problem, but before I take the whole thing apart, or order a replacement gear, I was hoping someone here has either an answer or has experienced the same problem and found a solution.
Thanks,
George
Thanks,
George
