86 vacuum line diagram? for tpi
Its Hood Light Manual switch. Ever see any Round single port accumulators in that front well???
What do you think of the BlueBook???
Looks like I'm out $5...:L
The round vacuum reservoir is OEM unit.
I know nothing of the blue book. I doubt it has any vette info, that's NOT in the red FSM...
Looks like EGR and Canister are fine. I 'm working with top rear line out of plenum to Cruise Control. Crossing over in front of Dist., theres a TEE just inches from Dist. #1 small goes round/down behind Dist. #2 larger goes to Cruise Control via a Accumulator BAll (not OEM). Its #1 going behind Dist. that is open??? I just can not find any possible connect unless somewhere against the firewall, it connects to AC/Heat???
Thanks for input both of You and if I figure it out, It will get to you. Going to JACK IT tonight and look from underneath.......
Shrade
Item: 1986 Chevrolet Corvette Factory Service Manual
Year/model covered: 1986 Chevrolet Corvette
Contents: This manual covers general information and service information for heating and AC, steering, suspension, tires/wheels, drive axle, brakes, engine, fuel system, transaxle, electrical, accessories, wire diagrams and more
Published by: GM. This is the original factory issued paper manual used the by the dealership's service department
Number of pages [approximate]: 1000
Size: 8 1/2" X 11" X 3"
Printed-revised: 1985
Binding: loose leaf in Chevrolet binder
Condition: used/information complete and legible/ fair condition
This is Description of the Blue Manual
Hi Dudes,
I found the vacuum line!!! It's black plastic coming out of the wire harness exiting the firewall behind the right valve cover. It broke off so short, I had to unplug spark plug wires, remove Dist. Cap and Rotor to grasp it well enough to force 1/8 Vac Line over it. Then bring it up to the TEE over the left valve cover which feeds to the Vac reservoir and the CC. What a Job!!!!!
I found www.boostcontroller.com who sells the Silicon Vac Line in 10ft lengths under a buck a foot and thanks for the Help.
Thank You all for your help and I'll watch for you in the future!!!:beer:beer:beer:beer:beer:beer:beer:beer
