boomdriver
I am pretty sure That I have one that got wiped out when the rear hub bearing went south....it looks as though the tip is broken off.
My question is,
does the sensor (87-rear) have a little lip or tip that is a flat edge that protrudes over the rest of the portion that inserts into the knuckle? I have searched the web trying to find a pic of a c-4 wheel sensor and cannot find one and NONE of the parts stores have it either. It's going to have to be a salvage part, I just want to confirm that mine is damaged and causing my abs to fault. It has NOT been scanned because nobody has a scanner for the 85-87 c-4 abs off-board system.
If worse comes to worse,. I can just pull the other one and compare. But age, arthritis and a cheap floor jack forces me to ask first..
My question is,
