boomdriver
I just replaced my compressor because the old one scattered and caused a shaft seal leak. As long as there was gas, the electronic a/c system worked as it should.
Now, the new compressor will not engage even with a minimal gas charge and jumping the low pressure cut-out switch. I have 12+volts at the compressor plug , the low pressure switch plug has 5v on one side and zero on the other. Even with the low press switch jumped, the compressor clutch will not activate. The clutch coil has zero resistance and carries voltage.The clutch is free to move and the compressor rotates. Its brand new.Never been run or installed. The ONLY thing different is the new compressor, yet it will not operate. The diode in the plug is intact. Blower and everything else operates as it should.The underhood fuse is good.
I vaguely recall something about this that tells me that having voltage at the compresser is meaningless without the end of that circuit being managed by the ECM and power module. I am thinking that the power module is fried from lack of cooling when the defroster button was used directing power to the compressor. Although the comp circuit was interrupted, that may have still energized the module and created excessive heat or resistance. With no gas charge the switches prevent the compressor from running. But, that has been jumped and there IS a minimal gas charge on the system at this time.
Anyone have any thoughts? I'm going blind reading the electrical drawings and want to avoid spending $125 on a module based on a "best guess".
What would help would be knowing more about what the voltages should be coming from the PM. I'm not going to run a jumper to the compressor coil. Its not a +/- type of circuit. The current simply has to move thru the coil to energize it by creating a magnetic field. Connecting a pos/neg to the coil would melt it down with battery voltage/amperage, if I am reading this right.
Thanks !
Thanks !
