vetteoz
Wait until you work on the heater. Rumour has it they put the heater core on the assembly line and built the car around it ;squint:One screw to remove and it has to be the most awkward screw in the entire car.
Thats on C3's!!Wait until you work on the heater. Rumour has it they put the heater core on the assembly line and built the car around it ;squint:
Not the way it is shown in '87 FSMThe path should be from the control head to the a/c heat programmer controller through the relay to the ECM to the loe pressure switch to the compressor.
Have you been able to see the afore mentioned voltage drop on the compressor clutch control wire to the BCM ( green / wht ) when A/c turned on?Process of elimination takes me back to the power module, again. I can take power from the compressor plug to one side of the coil then ground the other pole on the coil and it will engage.
