My 87 convertible was running great until a week ago, now it idles rough and varies between 500-900 RPM at idle, and surges or misses at light throttle when cruising.
I cleaned the MAF with the proper spray cleaner, and the throttle body too with little or no improvement.
I added Chevron Techron Plus at the last fill-up, no help with this problem.
I'm chasing vacuum leaks, and have fixed a few with no solution yet.
There are NO check engine codes,
even though I have made a few modifications such as, K&N air filter, air pump eliminator kit, disabled the EGR by plugging its vacuum line. I also added a chambered dual exhaust system with a new Bosch O-2 sensor that is too loud but I like it.
The car has been running great with those mods until this week, and it seems to get worse when it warms up, but it's never run over 185 degrees any way.
What should I try next?
Thanks!:confused
Thanks!:confused
