J
JD-vette
Hi All
I have a problem with 88 corvette.
year:1988
mile:125000
hard start but when it starts the engine sound very normal for couple minutes then die. I was able to pull a code by using the old method that short Pin A & B to obtain the code on information widow. it read 34. so I clean the throtte body,replace MAF relays,check MAF sensor and connectorm,clean IAC,But the same the systom is the same. If anyone have the same problem or idea please help me. I think fuel pump & filter have not been changed. Would it be fuel problem or injector system problem. Or do I have problem with start/ignition problem b/c when hard start, I try to jump and it start so easily. Please help.
Thanks,
JD.
year:1988
mile:125000
Thanks,
JD.
