1989 Brakes, Service:
Description: Hydraulic power brake front and rear disc base JL9 and heavy duty J55 systems
Brake type front: B.C.I.A. standard pin guided caliper
Brake type rear: B.C.I.A. standard pin guided caliper
Special valving type: Rear proportioner integral with master cylinder
Power brake: Standard
Booster type: Vacuum 9.4" single diaphragm 65 sq. in.
Vacuum source: Engine plenum
Anti-lock device F/R: Standard front and rear
Anti-lock manufacturer: Bosch
Anti-lock type: Electrohydraulic
Anti-lock number sensors: Four front wheel sensors
Anti-lock number hydraulic circuits: Three (two front, one rear) hydraulic
Anti-lock integral or add-on system: Add-on
Anti-lock yaw control: Yes
Anti-lock power source: Electronic motor pump
Effective area: 32.4 sq in (front), 18.4 sq in (rear)
Gross lining area: 33.0 sq in (front), 18.4 sq in (rear)
Swept area: 102.3 sq in (front base), 111.9 sq in (front HD), 91.3 sq in (rear)
Rotor outer working diameter: 11.9" (front base), 12.9" (front HD), 11.9" (rear)
Rotor inner working diameter: 8.75" (front base), 9.7" (front HD), 9.2" (rear)
Rotor thickness: 0.78" (front base), 1.1" (front HD), 0.78" (rear)
Rotor material and type: Gray iron vented (front), HCE iron vented (rear)
Wheel cylinder bore: 1.5" (front dual piston), 1.6" (rear)
Master cylinder bore: 0.87" (front), 0.87" (rear)
Master cylinder stroke: 0.79" (front), 0.47" (rear)
Pedal arc ratio: 3.5:1
Line pressure at 100 lbs pedal load: 1250 psi (front), 750 psi (rear)
Lining clearance: Self-adjusting, front and rear
Front brake lining bonding: Integral molded
Front brake lining manufacturer: Japan Brake Industries
Front brake lining code: JB CP26, FE code
Front brake lining material: Semi-metallic non-asbestos
Front brake lining size primary: 5.3" x 1.57" x 0.37"
Front brake lining size secondary: 5.3" x 1.57" x 0.37"
Front brake shoe thickness: 0.24"
Rear brake lining bonding: Integral mold
Rear brake lining manufacturer: Japan Brake Industries
Rear brake lining code: JB H3H B33, GF code
Rear brake lining material: Semi-metallic non-asbestos
Rear brake lining size primary: 4.25" x 1.38" x 0.33"
Rear brake lining size secondary: 3.7" x 1.38" x 0.33"
Rear brake shoe thickness: 0.16" (outboard), 0.22" (inboard)
