Rodney Gold
- Joined
- Jul 28, 2003
- Messages
- 200
- Location
- South Africa
- Corvette
- 1986 White l98 coupe, 1995 LT1 coupe
I don't think you can just disconnect the knock sensor as it will retard badly when the engine gets to 190+ degrees , I think you need to put a 4.7k 1/4watt resistor on the wire that goes to the KS and then ground that. It fools the ecu that the KS is still active but just wont retard any. I might be wrong , as this is what is required on my 86 to disable the KS - might not work for an 84
I would diss the ECU and use a carb/intake and a a MSD dizzy or the like and go old school.
