muddywaters
- Joined
- Aug 25, 2002
- Messages
- 765
- Location
- wilkes-barre,pa.usa
- Corvette
- 1988 white 4+3 coupe 99 Torch Red 6spd. coupe
Their should be a shield over the filter that has to come off first. If the car was sitting over night and wasn't started, with injectors that are leaking down ,you probably won't have pressure in the fuel sys.,I didn't, but it would be a good idea to check that at the schreader valve, otherwise you'll get some squirt gun action when you undo the filter, have a rag ready and watch the drop light. My 88 did the exact same thing your 89 is doing, started cold perfectly, ran good, fuel milage sucked, took forever to start when hot. I think it a common problem with the older FI Vettes. Mine never ran better, Good luck, Go Pens.......................Joe P.S. There's a lot of aftermarket CRAP out there, spend a couple of bucks more and go with a better AC filter.
