got the entire rear suspension installed today. The rebuilt trailing arms, half shafts, and strut rods from Van Steel came out GREAT and we got those, the differential, new KYB GR2 shocks, and the Van Steel composite leaf spring installed along with the Muskegon Brakes on the rear.
Muskegon supplied an entire "Super Brake Kit" including the calipers, pads, rear hard lines, front / rear flex hoses, master cylinder, and brake fluid.
we also got one of the #4 body mount cages from the underside of the body swapped out today.
next week we should have the complete front suspension and front brakes installed along with the drive shaft, install the other #4 body mount cage, and a few other items on the body that we need to do. By the end of next Sunday we should have a rolling chassis again and the replacement frame should be off the stands and back on it's own wheels. Hopefully a good day on the following week and we should have the body dropped back on (fingers crossed).
Here are pics from today:
http://www.vetteclub.org/1980_Project/projectpics7.html
