Wegone
I had the same issue with my 90, went thru all the steps listed. Tried for days to get the code (26) to clear finely I gave up and removed the bulb.
J37 said:P.s. The connector that I cleaned was the yellow connector under the steering cloumn (under the kick plate) [/B]
Wegone said:I had the same issue with my 90, went thru all the steps listed. Tried for days to get the code (26) to clear finely I gave up and removed the bulb.
Jeffvette said:Al, I have not heard a definite answer if the bag will deploy or not. You should definately pull the codes to figure out where the problem is.
alka1967 said:I just bought a "90 with this problem. I assume if the bulb is removed, the airbag will still work in a crash? Am I correct?
Thanks,
Al
Thanks for the quick and detailed reply. I guess this means the air bag probably won't work if the light is on or off. Great!AdvancedAutoCC said:Al,
Sorry, but you are incorrect.... when the SIR lamp is on, the system is disabled by default (to eliminate an accidental deployment), so no airbag system. This is similar to the ABS system not working when the ABS light is on, you have base brakes but no antilock.
Also, you guys who are pulling connectors, cleaning, etc... be ABSOLUTELY CERTAIN to pull the SIR fuse(s) after you disconnect the battery and not touch the system for 5 minutes, as the DERM will retain power (that's one of its jobs), and can deploy the inflator module (airbag). These airbags deploy with considerable power, and if you were to be right next to to it (like if you're playing around under the dash), it can conceivably break your neck! Most DERMS will drain power within a minutes, but some have been known to stay on longer. GM pounded this in our heads when SIR systems came out, and it's still good practice.
As an aside, I remember a GM training film where they were trying to deploy the airbag in a test Corvette at the Porsche proving grounds in Germany. They did a lot of stuff, hitting barrells, driving into gravel pits @ 100MPH, and my personal favorite; hitting a bump at 100+ and getting serious air, enough that when the Vette hit the ground, it broke the transmission case! Not once did the airbag deploy, though....![]()
