Question: '91 broken wire connection from fused lead at battery
xkalliber
New member
florida
black 91 convertible , red 95 coupe
I just put a new battery in and found this wire connection broken . I am not sure what it is for but looking to find where it came from if anyone can help . Car not started in 2 years and no sound from fuel pump when turning ignition on .
After pulling battery out again I did some digging and found the culprit ,it was pretty well hidden . the wire corroded off right at that connection . Hopefully my fuel pump will get power after I fix this connection . I have had a few instances in the past where the car would just shut down while cruising . This failing connection i hope was the cause .
