'92 plenum hose question
D
DaWoodster
Looking at a '92 ZR-1; There is a hose/nipple at the front driver's side of the intake plenum, that does a quick 90deg back to a smaller fitting between the first and second pair of intake runners. My guess is this is to feed a coolant jacket for the throttle body, but I'm not sure.
This particular car has the hose and connectors removed and has the large hole welded closed. Two questions:
- Am I correct in assuming it's a coolant line?
- Any guesses on why they would weld the hole and not plug it?
I have attached a picture to hopefully make this clearer.
My thanks in advance for any help.
U
USA ZR1
Looks like the coolant passage for the throttle body has been bypassed. Mine is done the same way. It keeps hot coolant from heating up the incoming airflow.
F
FrogindaBlender
Was this the white zr1 in escondido? I was over looking at it in my hunt for a zr1. I think that is a egr pipe. If it is that car. I bailed on the car because it looked really tired. Watch out for the dealer. They had a nice black one 90 they offering @23.9k and told me it was a misprint and would not let go of it for under 24.2k. Two weeks later the ad still show 23.9k. Thanks distictive auto. I bought a red/red 91 for the same 23.9k with 16k miles.
S
secondchance
Actually, EGR is on the passenger side. I think Clint is right. Looks like coolant bypass for the throttle body.
F
FrogindaBlender
I saw that car too. I just did not know, but it was one of the factors why I did not buy it. Looks like Wood is getting it. I smell DRAG RACE!
JT ZR-Won
Bradenton, FL
'90 ZR-1 #3010
That is the coolant bypass. However I have never seen one welded closed. No need to weld when a .50 cent cap does the trick.....plus, pretty tough to return it to stock form.
I bypassed my coolant as well so it wouldn't heat the plenum up as much but didn't weld anythng
Jay
9
91vettezr1
D
DaWoodster
Thanks, all for your help and input. As per my last post, I did buy the car, so I now am the proud owner of a coolant challenged throttle body.
Functionally, all seems fine, runs strong/well. But, man, that is one ugly weld, making for one ugly plenum. I will address it as time/$ allows.
I did find a new plenum, and yes, they do fetch a pretty penny.
"91", a special thanks for taking the time to post the pictures.
PS: Already have 2ea 911's and naive kid in a 300zx "enlightened". They didn't see my welded plenum, but they did see that ZR-1 emblem, the back one :)
