lakeguy72
New member
Backfiring/Afterfiring?
My Ruby(27000 miles) has been actingweird.
On a cold start(winter or summer), itstarts and runs like it should. After running or driving for 10minutes it starts popping out of the driver side exhaust. It doesn'tstall if you go easy on the throttle. After driving about 5 miles at45 MPH it runs perfect again for the rest of the drive. If you shutit off when popping and then restart it kicks like the advance is toohigh. If you wait about 20 minutes it starts and runs like nothing'shappened.
This seems to happen at around190+(digital) degrees. When the problem clears it's running around205+.
I heard that the maybe the ICM wasgetting hot but packing ice around it didn't help. Would a sticky EGRvalve cause this? I checked at night for arcing of plug wires—noluck. There is no sign of water pump leakage staining and the optiappears to be dry. No bubbles in radiator reservoir or loss ofcoolant. The car is not driven daily and this happens mostly whensitting for 2 days or more. My MPG is 25-27 so I don't think it's aopen loop issue as I've read that in open loop mileage drops.Everything is original. I can't see throwing parts at it if iteventually runs like it should.
If it was the O2 sensor I would thinkthe popping would be heard from both pipes. No codes thrown and no CEL.
Help
Lakeguy
Help
Lakeguy
