Gene D
93 LT1 only fires when throttle is pushed. Cranks with no start if pedal is not pushed.
I have to hold throttle about 1/4 way to keep at 1200 RPM.
I have looked for vac leak. Fuel pressure is at 41 psi.
I pulled and plugged all vac ports on the side of intake(the ones under black covers.
I checked all hoses from the air pumps on drivers side. (I think)
No check engine light.
If I put a vac gauge on one of the small ports on pass. side intake, What reading should I get while cranking?
Any other Ideas what could cause this?
